v8frank
Hi guys,
I have a problem with a push-button 727 transmission in a '64 Dodge 440 with a 318 Poly.
The tranny shifts only into high gear when I release the accelerator slightly.
The transmission works fine in all other aspects.
Going manually through the gears works fine. It will go into 3 rd even without releasing the accelerator slightly.
Kick-down works fine. The carburetor gets WOT.
I have adjusted the kick-down linkage to exact FSM specs but no change.
The transmission is all original except for a deep sump aluminum pan from Summit that was installed before I got the
car. I haven't checked if the filter in the trans has the correct 2 whole filter in it as I read somewhere that by using a
single whole filter/extension this problem could occur !?
Any ideas before I go into the transmission?
Thanks a lot in advance.
Best regards,
Frank
Best regards,
Frank
