Nico Buchner
Hi everyone,
I've been reading on this forum for a long time now and finally have reached a point, I need to ask for your help. I have already read every single article that included the word “surge".
I have a lean surge above 1500rpm that I am fighting for almost a year now.
Specs: Fully restored 68 Dodge Coronet with a mildly built 440. Comp cams XE268H, 9:1 compression, ported 452 heads, weiand 8008 intake with blocked heat, 1“spacer, QFT735HR, MSD6AL, distributor with mechanical and vacuum advance, total timing 36°, electric fuel pump with pressure regulator set to 6psi, 1 7/8 headers with 2.5“ exhaust, wideband O2
The problem: When I accelerate normaly, the engine surges. It feels like it has full power for one second and than no power for 2 seconds. During these 2 seconds the engine is shaking and goes way lean on the O2 (up to 16:1) until it goes back to normal for a second and everything repeats until I either lift the foot or go WOT. At cruise and WOT there is a very slight surge, too, but almost not noticable. It idles fine and starts up good. The problem seems to get worse, the longer I drive. Sometimes the surging is accomponied by a backfire through the exhaust.
What I did so far in that order:
- Had a Holley Street Avenger 770 on it before, that had the exact same issue. After messing with all adjustments for a while decided to change the carb
- Installed a QFT 735 HR
- Checked for vacuum leaks multiple times (including a smoke test)
- Checked transfer slot
- Checked if choke fully opens
- Adjust float level
- Adjust acc pump linkage
- Adjust idle mixture (best vacuum at 15 in N and 12 in D and A/F at 12.5 is at 1 turn out). The engine seems to like more fuel, the richer the idle mixture is, the better the engine accelerates. I was up to 2.5 turns out, but still had a very slight bogging and it seemed way too rich (tears in the eyes behind the car)
- Checked plugs with no signs of fuel problems
- Bumped up primary and secondary jets by 2 and than 4 sizes with very little improvement
- Played with timing of the secondaries. Later kick in made it worse, earlier made no difference
- Unhooked vacuum hose to distributor, which felt a bit worse
I am now out of ideas and would be very thankfull for every idea you have.
