cdr
Late to the thread if anyone is still subscribed (cdr) can you tell me what you did to correct turning radius problems. Just installed one on my 70 RR. Not at all happy with the kit.had to grind a lot on the main bracket to get it to bolt up to cross members, modify headers, will need to modify p/s pump bracket to clear a/c belts. Would not recommend anyone else buying one
on the pump i made a puller & turned the pulley around so the offset would clear the ac belts,for turning radius where the outer tie rod mounts i cut off the end of the arm on the ball joint ,drill a new hole in the arm & weld the piece that was cut off with the tapered hole to the bottom side of the now shorter arm lining up with the new hole, had to drill the tie rods for cotter pins & use short castle nuts that i got off the cars original tie rods.
the tie rods will still go in from the bottom side.
by shortening the throw on the lower ball joint the wheels turn more,the piece welded on the bottom has the taper you need & also by lowering the outer tie rod corrects most of the bumpsteer problems.
