ralley dash help.
Donahue72
7:50 PM
Taylor,PA
ok heres the story. bought a 72 charger that had hideaway headlights and a 150 mph ralley dash. tore the car apart and started my resto mod on it. decided one day to clean up my dash harness and i found a nice surprise. A dark blue wire off the fuse block must have grounded out somewhere and fried. took a few wires with it. then i noticed that the steering column conector had wires cut on it. it looks like this car may not of had the ralley dash factory and that some one added it later. all my guages worked before tear down but my taillights didnt. Wipers worked, heater worked, blinkers did not, head light motor worked, engine fired up, interior lights worked.
Does anyone have a ralley dash wireing diagram. I have the one from mymopar.com but looking at it, i dont see what i need. And does anyone have a how to do the ralley dash swap so i can use that as a base if a previous owner did do a dash swap. Im on a slim budget right now so im trying to save just about everything. Any help would be greatly appreciated
or if anyone has a reccomendation on what i should do will work too. knida new to the whole mopar thing and it gets very overwhelming.
I have one for a 73, if you want I can email that to you.
