I weighed the car today.
For a recap:
I was at 3980 after I did the 5 speed swap in January 2021. From then until I pulled the engine, I don't think that I did anything that would affect the weight.
During the project, I shaved some weight and gained a little.
The Dr Diff 13" front brakes shaved 14 lbs due to the aluminum hubs and calipers.
The Borgeson steering box and the return to standard ratio steering arms shaved 14 lbs.
Shorter rear tires shed about 6 1/2 lbs.
I have an aluminum master cylinder that shaved 3 lbs.
The hollow front sway bar shed 8 lbs.
But.....
I have a vacuum pump, storage tank and lines in place. That may have added 5-6 lbs.
I went to 11/16" tie rod ends and steel adjusting sleeves. That added maybe 2-3 lbs.
I had the spacesaver spare in the trunk. That added 38 lbs.
My weight today.......
3980.
I forgot that before, I didn't have a spare in the trunk.
All that weight savings only to balance out the added weight of the spare.
Ahhh, so what ? It isn't really that important. I was hoping to be in the 3950 range and aside from the spare, I actually am. I'm not road racing it in competition where every lb lost is a step ahead of the other guy.
The brakes do work well though. The alignment is so far off though, it is hard to keep it straight when I stab the brakes. I stepped away from the car awhile back to get Jigsaw registered. I can now alternate between the two.
Jigsaw weighs 3620 with a spare. That puts it around 3580 without one. Ginger is 360 lbs more.
The scales aren't accurate down to the pound though. They are in 20 lb increments. I keep going back there because going to another scale may bring different results and I'd prefer to be consistent.
