- 1:57 AM
- Apr 13, 2012
- Granite Bay CA
If you are running the Mopar Performance electronic distributor......The problem is the air gap.
The air gap is set at .008 with a BRASS feeler guage. If that gap slips and opens up, the car will run fine on light throttle but will sputter and stumble when you lean on it.
I had this very thing happen several years ago and it was embarrassing! I had just tuned the car, added new plugs and was at the dragstrip to see what it could do. It popped, stumbled and sputtered to a 14.83. This is with a car capable of a low 12 second pass.
The Mopar Performance line of distributors have some quality problems. Mine would slip and let the gap open quite often. It also developed a "no-spark" issue on occasion. I blamed everything else...Coil, ballast resistor, the 43 year old wiring too. I ended up pulling it to look inside. The reluctor wheel was clocked wrong because the retaining roll pin had fallen off and fell inside. HOW do you thing that would happen?
All is well with the ignition now. It helped to have spares here to test in the car.
