Rear door Panel clip position on '70 RR
wwheel
2:14 AM
Dallas, TX
I Have a question about the clip placement on the rear panel. I measured the position of the holes for the clips on the inner Qtr. panel and compared those to the cut outs on the door card. See attached. The black "+" are where the holes in the inner panel are.They basically match up except for the second to the last which is about an 1" off. (Orange circle) No way in hell that will work! The other strange thing is the very random orientation of the cut outs on the panel. All of the holes in the inner panel are in a straight line. Why are the cut outs at various angles?
These door cards are from Legendary. Has anyone used the cut outs as fabricated?
Thanks.
I gave up on the wire panel clips. 1) Too hard and time consuming to cut the openings 2) the cut outs were mostly in the wrong place on the Legendary panel 3) almost impossible not to have a lump show on the vinyl side. What I used instead is a Christmas tree fasteners with a 9/32" diameter shaft. See attached. These are totally flat and smooth so two sided tape sticks like crazy to them. Got them from Amazon. Stick them in the holes protruding out just a bit. Then line up the panel and push in where the tress are. BAM! Easy!
