Rear end question
VicL
8:53 AM
Franklin, TN
I just picked up a car that was originally a 1969 sport satellite convertible. I wanted to determine if it has a Sure Grip or open rear end. I jacked the back of the car up knowing that if I turn one tire and the other turns in the same direction it's a sure grip and if the other turns in the opposite direction it would be an open rear end. If I turn either Tire the other Tire does absolutely nothing but both tires turn the drive shaft. I've not come across this before. Any help or suggestions would be appreciated
Put it is park so the drive shaft does not turn and then see what it does. Pretty sure its an open diff.
Sounds like a one wheel peel with tight brakes.
Non SG
SG will turn both the same way.
Could be a broke SG but my bet is non.
Usually a limited slip will pull the other wheel with it through some friction, even.
A non- LS will not, but the friction may hold the other wheel.
If you want to be sure, you can pull the chunk and look.
OK, then.
Glad the mystery is solved.
