Rear leaf springs 65 Satellite...is there a right or left?
64SF
7:52 AM
Ocala,Florida
I'm about to reinstall the rear axel assembly and the rear leaf springs (stock from the car) and forgot to mark which spring was on which side. Is there a difference between right and left?
I did a search but didn't find an answer.
Are they numbered? If so, the odd number will be on the left hand side.
Otherwise, if they are identical....it doesn't matter.
Look at the configuration of the leafs. If they are the same, doesn't matter. If one has more leafs and/or the front half of the spring leafs are biased toward the front of the spring, that's the passenger side. Seems like my stock '65 Coronet spring were the same, but not sure.
