WTB Rebuildable 318 poly
62savoyguy2
3:31 PM
Plainville, Ct
Feedback: +5 / =0 / -0
Am looking for a rebuildable 318 poly. Mine has very low compression, under 100 lbs per cylinder. Would also consider a rebuilt, or good running one that might have been removed to install bigger cubes. Will travel within 150 miles of central CT for right motor. Thanks, Dennis.
I have two would make you the deal of the week on them
$400. One has the wieand aluminum 4bbl intake on it and runs great. The other is missing the cam and lifters. Everything else is there.
Will even throw in a poly 727 and poly 3 speed manual bell housing
Would probably cost a small fortune to ship, I am in Connecticut. Great deal, wish you were closer.
I pulled one from a 1966 Belvedere. I sold the cam out of that one.
The other one was pulled from my 1966 charger less than 3 months ago. It runs great. No leaks, doesn't burn oil. I just had to have a 440 / 4 speed in my ride
Let me do some research, will call Fastenal, there is one near me. Will be in touch. Thanks, Dennis.
Or you could "road trip" on down
Thanks
Joel
I have a 318 attached to a 727. I pulled it out of a 66 Coronet grocery getter. Was running, been sitting under cover for the last 4 Years. In Huntington ( westerm Mass)
