- 10:40 AM
- Jul 1, 2015
"HE" is a classic example of why "he" should let someone else rebuild his carbs....starting from selecting the correct kit, opening the box, identifying all the parts, correlating the different parts....although "he" will extol the virtues of his findings, piece by piece, adinfinitum, starting with the date,time, phase of the moon, cleaner used, as each component is removed and identified, prior to reassemble, the actual reassemble, and the physical installation instructions, component by component, prior to first start, the first start, and the individual adjustments written instructions vs actual findings and WHY "his" findings are different than what "his" buddy said....all encompassed by the white porch railing....of a pix of a meaningless car...having nothing to do with the subject....this guy suffers from an OCD issue...having to say something about everything....in great meaningless detail....like the torque value of the LR tire's valve stem cap.....Did you even read what he had posted?
BOB RENTON
