68Satellite440
Hey guys,
Im getting my big block 727 rebuilt. I was having problems with reverse lately and having severe cork gasket leak. I finally changed gasket and new fluid. Reverse has apparently burned up. Wont even try to go back, but 1-3 forwards gears seem good.
So with plans in the future of adding a Gear Vendor Overdrive, I decided i might as well have the whole thing gone thru and maybe even add a shift kit? Not sure if thats even needed or would be helpful.
The shop I’ve selected to do it recommends getting a new stall converter while having it apart. I however have no knowledge of how to select what stall i need and my understanding is I currently have the factory 11” HP converter. Im wanting to get something that will work currently and with my planned future modifications. Its currently very slow and hardly breaks the tires loose.
The current specs on my car is:
‘68 Sport Satellite, formerly was a 318 car, got pulled.
‘68 HP stamped motor, factory 440 and trans out of donor car.
Edelbrock AVS2 800cfm
Factory 906 heads
Factory Intake manifold
Long tube headers
8 3/4 741 case with 2.76 (replacing with 3.55 soon and sure-grip)
Factory HP cam is 268/284 with .450/.458 lift.
Planning on changing to slightly larger Lunati Voodoo flat tap cam in the future not sure whats best for a street car, feel free to chime in.
700- .454/.454 lift, power band is
0-5000rpm
701- .454/475 lift, 1000-5500rpm
702- .475/.494 lift, 1400-5800rpm
Im not sure what other info is needed to select Stall, and im sure being in the middle of upgrading the car makes it hard to find something that works for current use and future plans. But if anyone has any knowledge or advice, please help. Thanks, -Pat
Factory 906 heads
Long tube headers
0-5000rpm
