Recommendations for 833
paladin06
11:04 AM
East Valley AZ
I want replace my clutch, pressure plate and throw out bearing. Who do guys recommend to buy the parts from?
I recommend the Centerforce Dual friction assembly. Not sure if the throw-out bearing is included. Summit will probably have the best price...............................MO
If you are running it behind a 383, the middle grade Zoom is more then sufficient and nicely priced. Kit includes everything also..
Stock 440.
Built 440, or stock/magnum ? 11" clutch or the newer 10.95"?
Brewers performance asked? With the tranny in how would I know?
18 or 23 spline input?
Wayne/Dan
Brewer's Performance Inc.
10510 State Route 571
Laura, Ohio 45337
Phone 937-947-4416 or 937-698-4259
Fax 937-947-4419 24 hours
You might be able to take the inspection cover off the bottom of the bellhousing, and either try to count the splines, or look at the throwout bearing. the 18 spline uses a larger diameter bearing. Most applications used a 23 spline trans. but the case is the same for both. If you don't have an old throwout bearing laying around that you know the size of for comparison, and the splines aren't visible from underneath, you will need to pull the trans.
