Kartracer11
New Member
I wanted to know the thoughts on using a small block to big block conversion mount versus a spool mount remanufactured kit.
I pulled 383 from my '73 charger that has a small block K frame with a cut back oil pan and spool mounts. Since I know the Mancini spool mounts are dimensioned the same as the original spool mounts that were in it, should I just go back with them; or should I go ahead and put the conversion mounts from schumacher that will allow me to eventually put a full size oil pan back in it?
Either way, I am installing a remote oil filter kit and a small oil cooler to add capacity to the system so going back with the original spool mounts won't hurt me too much.
