Dragon Slayer
I disagree on your assessment of the KH rotor. I do think you have the hub, but the KH rotor at 1" thick and turned down to .88 or less would be below the .94 min and also obvious. Additionally, despite not showing easily, the KH rotor hat is NOT as tall as the Bendix. Your rotor has a tall hat. Maybe not an original Bendix, but it IS NOT a 70-72 KH which would be shorter.
While bearing set is the same A6 and A2, the Bendix caliper mount direct to spindle, and the KH have an adapter that mounts to the spindle and the caliper mounts to the adapter. That is why I am not sure how the rotor with a KH hub would sit in relationship with the Bendix caliper. The KH hub would push the Bendix rotor about 4mm inward but again it depends on where the machined surfaces are inside the hub. If they were 4 mm outward, the rotor would center but the wheel would track out the 4mm. Which would not matter with 70s skinny tires. The measurements are really very close. It would take me a while to get to it, but I have another Bendix rotor/hub I have not disassembled yet. I also have a pair of Dura Brake Rotors. So I could assemble one with the KH hub and the other with the Bendix and then measure dimensions and compare to the Original Bendix. What I do not have is a loose B body spindle to measure against.
