Replacing Passenger Window Glass
darc1722
10:50 PM
chicago
Looking for some help finding the plastic rivot for connecting the passenger window glass to the metal bracket on the bottom that rides in the lifting mechanism. Also looking for the plastic rivot on the end, I think it's called the door glass up stop plug. It's for a 1969 B-Body Convertible. Let me know thanks!
what fester said....
and find the guy with the gray hair!
When attaching, an old trick was to use a nut & bolt, but use a small piece of rubber tubing (fuel line) as a grommet inside the hole in the glass. (if I understand part of your question correctly?)
Either that or just buy a regulator on eBay or find a MOPAR junkyard.
Hope this helps.
PK
RT Specialties has the rivet for $3. I believe they have the plastic up stop as well. Check under Hardware on their website.
