supergluehero
I'm in the process of putting my parts list together to convert to Wilwood disc brakes and got into the master cylinder sizing. My current pedal has a ratio of 6.7:1 which would indicate that it's a manual brake pedal. From what I've read, the power brake pedal has a ratio of 4:1. I've got power brakes, so I'm assuming the previous owner put on the booster without changing the pedal to the correct one. I'm also putting in a TKX 5-speed from Silver Sport. I spoke with their tech support and they indicated that the pedal the provide in their kit has a 7:1 ratio. All the reproduction pedals I've looked at don't indicate whether they are for power or manual brakes. Wilwood tech support said 7:1 is too high for power brakes and I would need something like 3:1 or 4:1. Am I missing something here or do all the reproduction pedals assume that you're using manual brakes?
