From a quick look the only thing I can see in common with those two circuits is that the leads to the reverse lights/NSS and the wiper system are all in the same bulkhead terminal. Bulkhead terminal #1, pins A-H. C&D are the for the NSS & backup lights and E-H are for the wiper motor. A&B are blank.
i found the problem for reverse lamp coming on when i turn wiper switch on someone had taken a wire from reverse lamp harness and and made a pigtail connector and pushed it up into the missing brown wire for washer switch and tape it over with black tape. now i have to figure out the wiring connection for reverse light harness now has a short brown wire with a pigtail and a red wire that i have to trace to see where it goes.reverse light probably will not work now until i figure out the wiring from there.
