junkpile
I want to thank everyone for helping me before with advise.
My 69 charger, suspension will not raise up. I have done everything that was suggested to me, and here is where I stand. I have new shocks, used but good conditions big block torsion bars, all new bushing and ball joints. when installing the trosion bar on the driver side I disconnected the upper control arm and dropped it as far as it would go, the lower control are actually hit the K-frame so it would move no furter. the torsion bar was just 1/16 of an inch from going in the hex slot, so it was put back to where it easily fit in. All was reassembled and after all the adjustments were made the car settled out, the adjustment bolt is all the way in on the drivers side and can not be driven in any further, the passenger side is about 3/4" from bottoming out so it still has adjustment to raise the car. I am running 15" wheels with 235 60r15 cooper tires, measuring from the ground to the middle of the fender opening is 25" and will go no higher on the drivers side. The car used to sit really high when I first got it at 26 1/8" I want to have the ride height at 25 1/4" to 25 1/2" any Ideas what could be wrong? car was not wrecked or dropped. Just want suggestions on how to correct this to have adjustment back on the drivers side. Any help is appreciated. thanks in advance guys. Got to keep the old mopar on the road.
