arizona satellite
I just purchased heads from 440 source and they recommend using studs in place of the rocker shaft bolts. I looked through the ARP cat and came up empty, any idea? thanks Pat
If you can’t find a fine/coarse thread stud in the right length, most fastener supply houses like Fastenal have (or can order) fairly long set screws that work equally well as a stud. Set screws are normally made from high strength material and have a Class 3 thread which means you’ll have a tighter fitting thread in the head. I know 3/8-16 set screws are available in quarter inch increments up to at least 3” long. It won’t be self locking like a fine/coarse thread stud but I normally use Loctite on studs anyway.
