EngineerDoug
Hello all,
I've been slowly refining the tune on my six pack setup on a 493 stroker big block.
My question has to do with secondary metering plates. I came across a pair of secondary metering plates that accept screw-in jets, but they don't fit properly. They tend to interfere with the floats, as they are a bit thicker than the factory metering plates.
I've come across some comments that indicate the aftermarket plates are not to be used with the thin sheetmetal plate + gasket that lives between the holley metering plate and the carb body. I can see how this would yield enough clearance to allow the float to swing freely, but why would the thin plate = gasket no longer be needed? I would think you might be setting yourself up for some internal leaks across passages by omitting these?
What am I missing? Thanks.
