wcwilliam
I'm down to the paint and body work now on my73 charger, and was looking for some advice. It seems as if every forum has a different take. I went went down to bare metal and sprayed self etching primer over the car. Hindsight says I should've stayed an epoxy just as a general consensus. I understand I cannot put body filler over etching, so what I'm considering is sanding down the spots that will need the plastic filler to bare metal, applying the filler and shooting the whole thing in a 2k primer. Am I close to the right path? Will 2k be suitable to cover both the filler and etching primer? Then sand and base coat of color?
