I did the timing settings yesterday....man it runs great!!! I set the intial at 18 degrees without the vacuum and I have the plate adjusted in the distributor to 16 degrees so that puts my total at 34. Then I hooked up my vacuum advance to manifold vacuum and dialed in the can to give me roughly 10 degrees of vacuum advance as well so that put me at 28 degrees at idle......WHAT A DIFFERENCE. Runs snappy, no header glowing anymore, and seems to burn alot cleaner as well. I am going to leave it there until spring when I can take it for a ride, but I am confident it will run better. I had it running at 2000 rpm for a good amount of time burping the cooling system of air with the cap off and headers were not glowing like last time. I think that answers my intial timing and hot starting issues for sure! Thanks again Don and lewtot184! Getting very close to perfection! Next is a dyno run to see where my a/f ratio is throughout the power band come spring.
