I just did this on my 69 RR 727 auto. I PULLED THE TRANNY PAN, and valve body. Then the seal can be removed by tapping upward on it with a punch or screwdriver. I am assuming the trans is still in the car. Then you get a flat washer a little bigger than the new seal, and a nut and bolt about 3 " long. Then put the new seal on top, with the washer, and bolt sticking down thru the hole. Then put another large washer or bar across the bottom, and stick the bolt thru that one. Put the nut and washer on, and gradually tighten the nut. This draws the new seal down into the trans body. Make sure it sits squarely on top before tightening the nut. I heard about this method, and was surprised how easy it was to do. First try. No more leaks now. Also a good idea to adjust the low/reverse band while its apart. Install a new filter, gasket, fluid, and your good to go. The kick down band can be adjusted with the pan installed. My tranny works great now, and no leaks! Good luck.
