- 10:48 AM
- Aug 18, 2024
- Virginia Chesapeake Bay
Do you know, will they go through a gas mask like this?
Any catalyzed paint is bad for you, isocyantes. Goes right through any respirator, that's why a fresh air suit is recommended.
You won’t know without looking at the Safety Data Sheet (SDS) for the paint, but if @Bird 426 is correct, a full face negative pressure respirator with filters won’t work. You really need to see the SDS, and crack open the NIOSH handbook to determine what type of respiratory protection would work, either supplied air respirator or negative air respirator with correct cartridges to filter the contaminates.
