70sixpkrt
- 11:45 AM
- Jul 18, 2008
- S. San francisco, Ca
This is some good information.Let us know what happens.
The 12Y is OK for the street, but is too hot for the track. Change to a cooler plug. I always had better luck with the AC short reach plugs, don't remember the #, maybe 44 or45S. Or try the Autolite racing plugs with a short reach, should clear up the high end miss. IF changing to the cooler plugs does not work, then more fuel is needed as you are too lean. Maybe open up the metering block 1 # at a time. But if you drill yours out, there is no going back to the leaner setting if you get it too rich.Thanks for all the advice
I'm planning one more run to the track Oct. 17
I'm currently running Champion RC12YC
What do you think of these or do you suggest an alternatives
thanks
Enzo
