Sixpactogo
I never use the red X without an explanation why.Never, ever start a car and let it "warm up". The engine never gets warm enough to burn off condensation. It also runs on the choke which adds to the over rich problem and washes down the cylinders, which puts more fuel in the crankcase that doesn't burn off. If you are going start it, drive it. And not just around the block. It also burns condensation from the exhaust. If you can't do that its better to let it sit. Fog the cylinders for the winter layover.
I don't agree with the any claims of this one though. Warming an engine is not hard on it unless the choke is not set up properly. On fast idle the choke should be open giving plenty of air to not be washing the cylinder walls. Also, after it has been idling for 10 minutes try putting your bare hand on any part of the engine then tell me it won't get warm enough to burn off condensation. I don't think I want to grab the tail pipe by then. In my neck of the woods, I put a half million miles on my D150 440 truck from new in 1978 until the late 90's with only a valve job on the engine. When I restored it in 2015 it got a .10 over bore so all those warm-up periods it got in lots of -15F Wisconsin and Minnesota temperatures didn't hurt it and qualifies my beliefs.
