- 2:45 PM
- Nov 21, 2008
- In GTXtacy Illinois
It was the same driver in each car on different runs.
No fluid in the system....no beltLet me rephrase that question. Two motors, both assembled from the same plant, both with the same running specs from factory, every part essentially the same, one engine without a thermostat, one with, both checked, and deemed comparable, torque specs the same, essentially two identical motors, temp checks 31 times before and after duration same time...etc and both run the same quarter mile. How is this possible, or even possible?
C’mon it’s only been a day or so! I think RC is stuck in elevator w/o cell reception(?)Alright well spit it out already, ****
Both were run at 140*The T-stat hadn't opened yet so both weren't warmed up above the t-stats temp. You never said what the temperature was.
Hey, my brain is just ‘Day trippin ‘ here....and that's a kind of potentially disastrous situation to run a Hemi (or any engine) hard in the 1/4 with it not warmed up yet.
Yikes.
The automotive thermostat is one of the most misunderstood devices in the hobby.
Lots of folks seem to think that replacing a 190* unit with a 180* one will magically make their car run cooler.
Let's pause to remember that most automotive cooling systems are pressurized.
This effectively raises the boiling point of water above 212*.
This fact intimates that by design, an operating temp in the vicinity of over 200* is acceptable, if not desired.
At least one other member here understands, and as pointed out, the temperature rating simply dictates how quickly the car "warms up".
You guys are misinformed. My Road Runner ran at 200+ on hot days when I bought it with a 190 in it. I replaced it with a 180 and rarely ever see anything above 185 now. A thermostat is rarely ever in a full open position. It is usually fluctuating near the full open position maintaining the set temperature. If its purpose where only to speed up warm up why would they make different temp thermostats? This is engine cooling 101.At least one other member here understands, and as pointed out, the temperature rating simply dictates how quickly the car "warms up".
