- 8:31 PM
- Aug 5, 2011
- Lisle, HELLinois!
Yippeeee! Looks great!
You can remove the insulator and replace it after you solder the return port, with a modified bolt and seal it with some JB- Weld? I did this when I added a extra circuit for my low fuel warning light that I added.View attachment 1162885
Mercy, there must be a dozen threads on here about return lines on our cars....
and yes, I've found the easiest way to search FBBO is actually to go to the google website and
search from there, as the search box on here is famously wonky as hell.
Easy-peazy! Nice.I think the Wix isn't metered, as opposed to the original 440 type which has the .060" metered orifice. Seems to work well for many though, including a fair number of forum members.
Well, I took the plunge and did it already, and - sure enough - the 150W iron was only hot enough to get the solder onto the surface, but following that up with a small butane torch did the trick. I wound up using a socket as a heat shield and heatsink, and it worked perfectly.
Now, if it's not clear in the photos, I did wind up tilting the tube up, for better or worse. I was going off of some original 440 senders and it appears as if they were designed to dump above the fuel level, so I imitated that. Probably because they were metered.
I went ahead and started soldering before anyone had posted whether to point it down or up, so apologies to those who have suggested otherwise.
However, there's nothing stopping me from flaring the end for a fitting and connecting an inverted J-bend back down with an extension. Come to think of it, it may be the only way to do it and still get the sender to slide into the tank.
Makes sense. Seems to work pretty well for many on the forums though, and there's one or two videos on YouTube praising it. Doesn't necessarily mean it works for all situations, but I don't mind giving it a shot.
FYI, the vapor lock wasn't the primary issue - I'm installing an electric fuel pump at the moment - but I decided to add it into the mix as it'd be an opportune time to drop the tank.
Duly noted - see my reply to 70chall440 about my error in pointing it up.
-Kurt
The Wix filter is metered. Looks to have a 0.060" orifice in 1/4 tail.I think the Wix isn't metered, as opposed to the original 440 type which has the .060" metered orifice. -Kurt
Really?! The Wix filter will return to tank (through an in-built restriction) what ever is at the top of the filter, be it liquid fuel, or if fuel vapours are present (that will float above the liquid fuel), then vapours...What I believe is these filters are just a way of returning a metered/restricted amount of fuel back to the tank. Not vapors. What it is doing is allowing cooler fuel to be circulated throughout the system and hopefully lessening vapor lock. Without the return fuel is deadheaded and prone to higher temperatures. Will all this fix the vapor lock? Jury is out.
Hope it solved any issues you had cudak888.
It solved all my vapor lock issues. Tried electric pump with no return, still no good. Added this Wix filter and return line, all problems solved. I'm sure it would have worked a treat with stock mech pump, but I wanted electric pump for quick start with dry carbs.
Hence why I built my own relay/timer system to run pump 15 sec on key on (I have 2 AFBs to fill) and to to turn pump off on oil pressure loss.My only regret is installing a 3-second fuel pump ignition timer. It's fine if you're running a high-pressure EFI system, but I find that I have to turn the key about 3 or 4 times to fill the bowls when absolutely dry. Wish there was a 9 second version of the same, or a higher pressure Carter pump. Though, given the choice and if one hasn't already invested in the wrong system, I think it's still a LOT easier to do an in-tank Tanks Inc. conversion than an external pump. More options, less fiddly, and a lot quicker to install.
-Kurt
