arizona satellite
I am putting together a 440 and was thinking of using the mopar performance 312/ 590 solid cam. Actually the engine is done but has not been installed or even started and the idea of changing the cam to a solid type came to mind. Let me give you the specs on the engine as it stands now. std bore RV block, KB 236 pistons with the quench dome milled off, H beam rods with ARP 2000 cap bolts, a .010-.010 steel crank, the current cam is a comp 305H with .525" lift. the heads are 440 source stealth units with the locks upgraded and the springs checked the engine is topped off by a Edelbrock torker II single plane manifold. I am currently using the stock valvetrain but have both procomp 1.6 stainless roller rockers and 440 source roller rockers also in 1.6 ratio. I plan on using a 850 HP holley carb with a 4 corner idle circuit. from what I have laid out what is your opinion on the solid lift cam? this will be an automatic with a 4,000 stall and 4.56 gears in a 67 satellite. thanks.
