like this 1..
HUG 6213BB
OIL PUMP DRV SHAFT W/ TREATED STEEL GEAR
BIG BLOCK 1045 STEEL SHAFT W/ HARDENED TIP & TREATED STEEL GEAR
$178.95
We now offer the chemically treated (melonized) steel gear mounted on our custom made 1045 steel shaft for big block engines.
The "treated" iron gear is a lifetime gear that can be used with any cam. The shafts are made exclusively for us and are available separately by ordering part #6220. The shaft and gear are assembled and pinned here in our shop.
High volume, or high pressure oil pumps are not recommended as they accelerate wear on any cam gear and oil pump drive gear.
Any new (or cleaned) cam - roller, billet, cast, flat tappet, or what have you...cleaned means no residue from the old gear.
