- 10:08 AM
- Dec 14, 2008
- Long Island,New York
70rcode,your right and it's big enough~
What size is the roller wheel?This appears to be the listing. Application is for AMC, must have been superseded . Please call comp and verify it is the new 848. Pushrod oiling able and pressurized oil to the needle bearings and rebuildable.
https://www.jegs.com/i/COMP-Cams/249/861-1/10002/-1
I agree, although I'd like the RPM capability to be at least the 6,200 redline I have now, (stock 6bbl bottom end). I can get a taller rear tire, and hold off on switching back to 3.54 from 4.10 gears.A 541" engine might make some good power to 5000 RPM. Or let's just say you should not have to spin it to reach the power goal. You want reliable. Well, here you go. Cam specs that require a lot of valve spring reduces reliability.
Although crap gas isn't an issue for me now, I envision a future road trip drive to Oklahoma to see Farmtruck and Azn, and "Power Tour" type events. I know thatI'd focus on using the cubic inches to my advantage. Keep the compression on the low side so it can deal with crap gas in high temps.
I am more interested in a fat torque curve than peak horsepower. My torque number goal is 700 ft lbs.Focus not on peak power but on making the most average power in the RPM range you will spend most of the time.
Hydraulic roller?If you can get a roller on a cast billet so you can avoid running the bronze oil pump drive I'd use that. Set bearing clearances for a 30 wt oil. Too much viscosity will put a strain on the oil pump drive gear.
The Weiand intake I'd really like to use doesn't have a heat crossover. Definitely not a daily driver, other than the week of Cruisin the Coast, or the aforementioned cruising events or bucket list trips.If using a carb I recommend keeping the intake heat open but insulating the carb to control fuel bowl temps. The hot intake will be excellent for daily driving and cold starts. Keeping the carb cool will help with the vapor lock after shut down. EFI will be the best since it's a closed system.
Educate me on solid rollers and street use about:Street solid roller
Thanks. It just seems like hydraulic flat tappet lifters would "hold me back" with the 541 stroker build, although the Comp Cams HFT lifters I put in my 440 6bbl a year after I got my Roadrunner (6 years ago May 2014) have been flawless and go to 6,200 RPMs in concert with the springs, locks, and retainers I got from Comp. I put Comp hydraulic roller lifters in the warmed over 421 Tripower, and the Comp Cams cam, springs, etc the engine builder specced for it, and while it's bore to stroke ratio isn't as conducive to wind as high as my 440, it's running H beam rods, ARP hardware, forged aluminum pistons, so it can spin up pretty good too, and I've had no problems with it either.Well I'm sure the guys here who know a lot more than I do about s/rollers as I've never ran one on my junk so all I can tell you is what we've done with ours and thats about it. The spray bar oiling you won't have cos of the 270's, we have it cos of the jesels/heads. Even that is ok for the short journeys to and from the track and the odd show John goes to, all in all so far this year he's done approx 70mls only and all looks ok, its stop start and low revs that are not so good but all you need do is keep rpm's up in that event, otherwise they work well but again its not in your criteria.
The motor has had 4>5 dyno pulls and these 70mls on them + around 15 -1/4m runs to date, we checked lash recently and they were spot on, as far as rebuilding lifters I couldn't find a bill for the lifter type but they are mostly all rebuild able I believe. Not sure it would be the best way to go as you plan on doing 1000mls+?....plenty have done it on and are doing it on drag week, but......The benefits for you of a s/roller are negligible, there's plenty of sft cams that will give you a 6200rpm max power potential and more without the need for big spring pressures and therefore you could use HS r/rockers which are reasonable on price, only downside to an sft can be break in and wear as you know, but with edm lifters etc., I would contact (fast68plymouth) the cam guru for advice, I asked him about an sft for ours and he didn't think going too radical was a good idea, .650-ish was his limit depending on the lobe types. I don't know what material they use today for them but back in my day the CC .650" sft I ran gave me no probs and I broke it in myself with the double springs and nor did the DC .590 sft in the 340 car. Anyhow I'm sure you'll make the right decision and everything will work out just fine
Good example my friend, because I know you street drive your car, AND it is quite the ride (I'll experience first hand one day)I use comp solid roller with push rod oiling and pressurized oil to the needles. They are AMC 848,but they have been superceded.
Cam lift under .670 with 550 lbs over the nose and go 5k miles before the lifters needed rebuilding. I street drive and beat it regularly.
In a normal year I might get 30 or so 1/4 mile laps and driven to several cruise nights. SFT lifters have their place and I don't care for them.
Is there something in between for a Dana 60?
Solid flat tappet lifters I have thought would be the best low maintenance high reliability option? Especially for a lot of stop and go traffic.
Although crap gas isn't an issue for me now, I envision a future road trip drive to Oklahoma to see Farmtruck and Azn, and "Power Tour" type events. I know thatJim Laroy has made good power without much compression.
Hydraulic roller?
6bbl setup, even if EFI, is a must, non negotiable. "Cold" definitely not common where I drive and live and race.
Good advice, much appreciated!
Thanks...A solid roller is a viable option, but much more expensive and may not have the reliability you would want, also probably not much more performance.
The needle bearing lifter has been around for a long time. It’s a durable design assuming it gets the needed lubrication. The issues that occur using this design on the street seem to stem from too much or too little valve spring pressure or too little lubrication. Set up properly, they’ll do the job reliably. Bushing roller lifters are the new trick of the week. We’ll see how well they hold up.I think the rebuild/replace due to maintenance is more of an issue with a needle bearing lifter.
Yes, none of this technology itself is new, but as for lifter availability and use in the high performance world, it’s the latest flavor. I have a set in my current combo.Bushing lifters aren't new, they have been around forever.
The newer (if you can call it that) trick of the week would be the Morel's I posted though they started development in 2010 and tested until 2016.
That technology is actually old as well however, starting with big diesels. (No bushing or bearing, axle dissimilar metal to wheel and direct oil fed like a main bearing).
I've not seen any reliability issues with them but the upside is, if it did have a failure it doesn't send hardened needle bearings into the bottom end.
Agreed that valvetrain instability/lubrication is the most likely causes of failure vs the design of the lifter itself.
...The whole "rebuilding lifters every xxxx miles" isn't something I want to deal with. .
