GTXGreasemonkey
I'm replacing my spark plugs and removed 5/8 Champion plugs. I ordered NGK plugs and recieved 13/16 plugs. They thread in surprisingly, but should/can they be used?
actually all import plugs go higher in # for lower heat range and domestic plugs go lower in # for lower heat range.no idea why.click the link click auto fillin the blanks and see if your plug comes up...
http://www.ngksparkplugs.com/part_finder/index.asp?mode=nml
I switched many moons (maybe 12 years now) ago to NGK's won't use ANYTHING else ... if you like em...you might want to "favorite" the website and read up on heat ranges..seriously...NGK is rated backards yeah I said Backards...lolol but they are some nice plugs..!!
