bandit
Been trying to calibrate my speedometer and have it where it reads pretty close now. Problem I am hitting is the needle hangs up sometimes on deceleration because of how far I had to back the return spring off to get the needle accurate. The magnets have gotten weak over time I guess.
One idea I have is to somehow try and add magnets to make it stronger so I can put more tension on the return spring. Concerned they may fly off though. Another idea is to decrease the speedo gear at the tranny, again so I can add more tension on the return spring at the speedo. My current speedo gear at the tranny is correct for the tires, backend gears.
Any ever tackled this? Thoughts on best/easiest way??
