artr8
I don't know if this is directly related but; read the story.
Small block in a Plymouth would run fantastic. Then, while idling at a stop light, would stop like I turned the switch off. Would not start in neutral but would in park. Doesn't make sense, does it?
The problem, we added an aftermarket distributor. You know one of the self contained. At idle, with the added load of brakelights would pull enough voltage to drop out the 12V needed by the distributor. When restarting in neutral, had the foot on the brake. (also part of the problem was a low output alternator with a large pulley)
The cure was to put a relay powered by the car signal for ignition. The power source ran from the battery, through the relay, to the ignition system to provide the full 12v needed. Cured all of the run problems.
