hunt2elk
Curious as to where you bought your springs? You probably posted it before, but what size tires and wheels are you running on your Coronet?The front brakes are done. We started working on the rear suspension. Installed 1" lowering springs along with Koni shocks. Changed out all the rubber bushings for poly. Got a little hung up because now the trailing arm bushings are off by 1/8" in the mounting brackets. I have the panhard rod secured hand-tight and upon research I need to disconnect it completely to release all preload on the suspension. Should finish up this weekend.
