Cornpatch MO
I am ready to first fire my 1978 440 engine with the stock starter. My vision is not good enough to read a the wireing diagram and not finding what I need in a google search ( not good at searching)
I temporarily want to use the bare minimum to get it started. The starter has , I think,the main battery cable stud and another smaller stud? what feeds the smaller stud? Do I need a starter relay?
I will run a jumper wire from a 12 volt source to the coil for power to the ignition points. Not using a ballast resister for the no resister needed coil . I will use a remote starter button--what do I connect its two leads to?
I wish I could find a starter wireing schematic that was large enough for me to read. Thanks for any help............................MO
