Ranger16
OK, I just came back in from messing with mine. I checked continuity again on the ballast resistor bypass wire from the bulkhead and it was good. I then pulled the center connector off of the bulkhead. All the connectors where clean (except for dielectric grease). I plugged the connector back in and then grabbed the brown bypass wire (circuit J3) with needle nose pliers and gave it a push just to be sure it was seated well. Got in the car and turned the key and she jumped to life almost immediately. Started like that 3 times. I am fairly confident that the disconnect was in the ballast resistor bypass wire connection at the bulkhead connector.
