deedohaw
- 9:25 PM
- Jan 28, 2011
- Scarborough, Ontario, Canada
So... we finally got son Michael's '78 Cordoba plated and insured. It started up every day just fine... but for it's first proper drive today it started up ok but only ran for about 1 minute then died. It started up again and ran for 30 seconds and died. Ether got it to fire for 2 seconds. When it sits for a few minutes with ignition off it will then run for a 1/2 minute or so. Swapped the ballast resistor... same thing.
What do you think? Fuel pump? Ignition?
It is a totally stock 360 lean burn.
Thanks, David
Thanks, David
