steel crank 440 -727 - 11x2.5" brakes
shopguy
10:55 PM
NJ
1969 Steel crank 440 cu. in. Mopar (Dodge, Chrysler, Plymouth) big block engine. Full valve job, +.030w forged pistons, 6 qt. B/E body oil pan, new Eddy performer intake, fully balanced. Professionally built. $3000 in machine shop work alone! Engine is a non-HP market. Has an upgrade Crower Cam. Est. 400HP/400FT.Lb torque. On the engine stand, never installled or run.
1969 A727 big block automatic transmission. Professionally rebuilt too. TCI valve body, standard pattern (not reverse). Never installed, never run.
$3500 for the engine, $750 for the trasmission. $4000 for both. I will not sell the transmission unless the engine sells first. My luck, I'll sell the trans, wind up using the motor and have to go shopping for a trans! Thats NOT want to do!
Pick up in Hamilton, NJ - Near Trenton of I-195
Also Have clean / painted 11x2.5 brakes for a 8.75 rear. $150 plus the ride.​
brakes sold.
Best offer on the engine - trans!!!
(makes a great Christmas gift!!! lol)
thanks for the offer...but too low.
Mike
To the first with cash: $2900 for the engine only ; $3500 for the engine ane trans.
Mike central NJ pu only.
what exactly do you want to see? shoot me a pm with a number and I'll call you.
Not sure if this helps:
On the pad: E 400 with a 5 -14 under it.
On the block: 2536430-8, Night shift, 2-24-69
$3K for both the engine and transmission. Will hold in storage on a deposit.
PM if interested.
