Mopar1969
I have rebuilt many of them over the years and put a new pin in the shaft. Just about everyone I did I had to use torches to heat the shaft and then knock it out with a punch or if you have a tool to presss it out you can use it but almost all I did would not move not even trying to press them until I heated the shaft with torches. Did you buy the Flaming River coupler ? Can you post a pic of the Flaming River coupler you bought if you did buy one ? Ron
Can you recommend a cheap(ish) torch that will do the trick? So my handheld heat gun that heats to 1200 degrees won't work? I'm attaching a picture of the coupler. I haven't bought it yet in case I ran into trouble getting this pin out...
