miller
Haven't fooled with a 72 RR, but no reason it would be different. Good deal on the fixed steering box.
After you mount it up, it's all really basics. Pitman arm only goes on one way, same as the steering wheel, located by the master key.
Center the steering box, via the pitman arm, center the steering wheel, and work on keeping them at those locations. As far as I know, the tie rods should both be the same length! Might check with a parts house on that, for your 72.
Then mount up your tie rods, without moving the pitman, or the steering wheel...the tie rods 'should' mount up fairly even on both sides. Start the threads as even as possible on each end, turning each until the tire on that side is somewhat straight.
Just a ball park toe-in number would be 1/16" - 1/8".
With the steering wheel, and pitman, still centered, adjust each tie rod until the front to rear outer edges of the FRONT tires line up with the rear tires. Either a chalk line, or tight string will help on that.
Then, simply turn the tie rods an equal amount in, on each side, to get toe-in. Use those outer edges of each front tire to go by. Total toe-in is both added together, fronts of the front tires being closer than the rear edges.
That will get you real close, and where it should be.
