steering pump needed
dodge71demon
11:52 PM
Indiana
I sent my TRW/Thompson power steering pump in to get rebuilt and UPS LOST IT.Need pump - housing - pulley for 65 b body I have the brackets or info where I may find one
It's hard to tell what will be correct for your application. Your car has been converted so it may be hard to determine what it should have. Do you have a photo of what the old one looked like? I have a couple different early big block pumps but they have different features. The late '64-6 type have the power steering cap with the lugs on the cap where the early '64 and older have the lugs on the reservoir. They also made a hex hole shaft and a plain solid shaft. The hex hole type use a 5 1/2" diameter pulley and the plain end shaft has a 4 13/16' diameter pulley. The offset seems to be the same. I'm not sure if the shaft diameter is the same. I can post a photo if you'd like.
Thanks, Mark
it was a 383 then at some point the 440 was installed so I do not see that as an issue.The pump had a plain end shaft
P/S pump
Here's the plain end shaft type that I have.
pimp
that would be the correct 65 , 66 ps pump. bigblock
