skag101
Yeah I had brakes before. I have only drove the car a couple of time since I bought it but they did work. Its really weird. I have never had anything like this happen and I have put on a lot of brakes in the past years. I'm pumping fluid to all wheels when I bleed them. Would the length still affect it? Ill try anything once. LOLI'm thinking it has something to do with your push rod.
If the rod is too short you won't be able to move the piston in the mc. If it's too long or not inserted in the hole in the piston, it will have the piston located beyond the fluid holes, inside of the mc and won't draw fluid.
Try taking the mc loose and see where the rod is.
You can also look under the dash and see what is going on from the peddle to the back of the booster.
I'm also thinking that the rod can come loose in the booster on some units. When you reinstall the mc things are not connected. (This last statement is just a guess. It's been awhile.)
Did everything work ok before you replaced the sticking caliper?
