resq302
I agree with the thought that you still have air in the system. When I was pressure bleeding out the completely dry system in my Dad's 69 GTX vert, it took forever to get all the air bled out. I thought I had the issue fixed and then the pedal was still low and would barely stop the car. I put the pressure bleeder on the car again and went through every bleeder starting with the furthest to the closest. I also filled a clear jar with some brake fluid and put a hose onto the bleeder with the other end into the fluid. While I would crack open the bleeder, I kept checking for bubbles coming out in the clear jar of brake fluid. Once the bubbles stopped, I let it go a little more and then closed it up and moved onto the next closest one to the master cylinder.
