moparnation74
correctSo these should be the good 14x6" wide rims for 1970 cars. I am looking for 14x5.5" for my 67 GTX.
Hi Moparnation74 so how do you decipher the date and size of the rim? Is there a look up table?1/17/70
no look up table for steelies....just in my head from years of searching and examples I made from picture. Very few references...Hi Moparnation74 so how do you decipher the date and size of the rim? Is there a look up table?
Correct...that is MW formatView attachment 544159 View attachment 544160 I've found this decoding of rims interesting. I've included a couple shots of one stock wheel from my '68 Coronet Deluxe built on May 31, 1968.
If I read the stampings correctly I come up with a 5" wide Motor Wheel produced May 11, 1968. Is this correct?
The "hubs" are not dated pre 70.....70 and above the hubs have datesFor those that do have rims with no tires on them, you also have more clearly stamped info on the hub inside. These stamps have a higher survival rate protected from the weather. Good informative thread.
5/13/73 Kelsey Hayes.....left side of the valve stem K23 5 then on the right of the stem is 13 675. Guess I'm dense because I'm still not able to decipher them....done too much of this over the years![]()
Thanks....but I can see where the 5 and the 13 come from but is the 23 for 1973? Is the 675 a part number?5/13/73 Kelsey Hayes.....
The 2 is for shift from what I have seen...without seeing the rim face I assume it is a later time hence 3 for 73....you guys have to post pics....if there is just 3 dimples to hold the hubcaps then I would say 63.....without pics we are guessing...Thanks....but I can see where the 5 and the 13 come from but is the 23 for 1973? Is the 675 a part number?
1973....Thanks for the link....Pics are here.....1st post. http://www.forbbodiesonly.com/moparforum/threads/older-15x7-wheel-id-please.141356/#post-910828165
Are you positive; these are 1968 Hemi type along with other C body, have matched set of 5. While the same exact date code as stamped on completed rim is not there, you still have the plant and year code, size, along with other information.The "hubs" are not dated pre 70.....70 and above the hubs have dates
Do you know the difference between the hub and the rim? You stated hub and not rim.....look at your original post....Are you positive; these are 1968 Hemi type along with other C body, have matched set of 5. While the same exact date code as stamped on completed rim is not there, you still have the plant and year code, size, along with other information.
I would have to check size but have a full set on a 67 coronet 440. I have no desire for skinny steel wheels. What would they be worth?
Speaking of rims not sure if I should post here but since people are looking at this thread, I have a set of 14" early style 10" dog dish, are in great shape, not crusty, is there a market for those??
Made a mistake, but I was talking about wheels with tires off so that would be the exposed area and more readable.Do you know the difference between the hub and the rim? You stated hub and not rim.....look at your original post....
Not all "rims" are dated but doesn't hurt to check
