Supercharger guys need spark plug ?
SUPERSTOCKRACER
12:24 PM
Oblivion
hi, need a NGK or equivalent spark plug on a 588 hemi blown with bds 8-71 supercharger pulley ratio is 1:1 and right now compression is 8.5:1
right now champion plugs im running are C63cx with gapless straps on them.
Maybe GR5IX for ngk. The only thing they list for a 7L r code which I assume means for hemi. But id go atleast one or two steps colder on the plug.
i kinow about clubplug but i need the right plug for this application.
i dont know which plug to go with.
I would suggest contact the plug MFGR or your engine builder, get their opinion 1st... what type ignition is it, what type fuel, what camshaft & what heads are you running {possibly call that head or camshaft mfgr too}, what heat range are you after, what compression ratio, dome or flat top pistons, is it single or dual plugs, is it aluminum heads or iron heads, what size plugs & are they long reach 14mm x 3/4" or short reach plugs ?? allot of variables
What super charged car ? Didn't know you messed with anything but NA motors!
is there a smiley for head scratcher
seems like there's a lot of head scratching going on
Is the combo top secret or something ??, why so vauge ??, do you want help ??, did you find the information already ??... Maybe if you give more us some more information, maybe someone can give an educated, knowledgeable or qualified answer, I/they would just be guessing otherwise, I'm not an expert either, just trying to help you... There's a great book "How to build Max Performance Hemi Engines" by CarTech books, writen/author by a FBBO member here Richard Nedbal owner of FastManEFI & a machine shop, maybe you could ask/call/contact him... SSR the coldest plug I used on a smaller 540ci Milidon Mastadon Hemi Blown/12.71:1 Mert Littlefield w/teflon strips & 20%-30% overdriven, w/Enderle Bug Catcher FI Hat & down nozzels, w/180A mech. Enderle Pump, appr. 10:1 semi flat-tops Venolia custom pistons, Childs & Albert Zero Gap Top rings, w/0.050"-0.070" thick Hussie dead soft copper head gaskets, 170cc Combustion Chamber, 0-ringed block, CNC ported Aluminum heads #P4876355 w/2.25" int./1.94" ext. valves & custom blower grind from Crane Cams 0.750" 292* roller & Vertex Magnito @ 36* locked down, CRC Methonal fuel... coldest c57 Champion or NGK equivalent 5672a-10 {I think}, hottest c63 Champion or KGK equivalent 5672a-8 {I think}, mostly depending on what altitude {higher hotter plug} & what thickness of head gasket & how much overdrive {more the colder the plug}, what nozzels or how good the track was prepped...but I highly doubt that will help with your combo... it may not even be in the correct range or style of plug for your specific engine...
i got the information i needed so no need to reply. i see that these spark plug threads dont go very well because most people dont know about hemi's
just ordered a few sets of the correct plugs from club plug.i went with NGK over champions this time around. I cant wait to start cruising with my 1st street hotrod in awhile.
Which ngk plugs did you go with? Inquiring minds want to know. I too have a blown hemi project. Are you using factory iron heads?
good deal, have fun with the blown Hemi combo...
