abloch
Evening all,
So I bought an old/new solid state tach this weekend at the swap meet and I am having some issues. I've spoken with the seller and he tried to help as much as he could.
Here's the basics. 62' Fury factory wiring harness, coil, ballast resistor. MP orange box, distributor and new solid state voltage regulator. Red wire from tach goes to fuse block for keyed 12v. Black jumper to battery for ground. The green wire is supposed to go to the - of the coil or the gray/black from the orange box. I have tried these and the + side of the coil and I keep getting the same reading. "key on" and the tach reads 2000rpms. Turn on the motor and the tach runs in reverse. I even read about switching the polarity be flipping the distributor leads from the orange box and still no go.
And and all suggestions would be greatly appreciated.
Andrew
Andrew
