Rick69
Hi! Hope everyone is healthy.
Doing my first rear main in a 440 on my back in the garage. The engine is stock.
The leak was not there at idle but started to drip when increasing the RPM.
All dry above from the valve covers and pressure switch.
I dropped the pan and windage tray. Removed the seal cap. Surprised at how easy the upper half came out!! It is a Fel Pro part #P-91020-1. Black.
Also, I noticed there were no side seals. The grooves were filled with black RTV. Anyone doing that?
I have a Mr. Gasket Seal Kit #1968. Is this a good option? Should I order a Fel Pro kit?
I am planning to install using the side seals. Should I be putting RTV on the side seals when I install?
I do have Locktite 518 for the seal ends when I reinstall.
Any comments and advice are welcome. All the posts are great.
