Roger63
So this was me today when the Dr cut me loose
Not yet I have to get back home to see my primary doctor 1stI don't like hearing "Dr" and "cut" in the same sentence! Lol.
Did you schedule a date for surgery?
Ditto. They found the tumor on my left kidney quite by accident, doing "old man scans" in 2013.In early 2017, I went to see a Dr about my nervous stomach. They did an MRI and a CT scan and found the same thing that you did. Docs said that kidney stuff like this is most often found by accident. By the time real symptoms show up, it is too late to do anything. I had a partial removal using the 6 armed robot and have had follow up scans and X rays since. I've been fine. You will be too. Stay positive.
I'm not to worried about the surgery, it's the recovery. I'm used to doing what I want when I want. Doctor is telling me 4-6 weeks of light duty and no work. Like I need more time off this year. So far I've only worked a grand total of 8 weeks since January 1st.Ditto. They found the tumor on my left kidney quite by accident, doing "old man scans" in 2013.
Saved my life in going in when I did, despite not having any inkling anything was wrong....
The tumor grew from the size of a walnut to the size of a softball in less than three weeks' time.
I also had robotic surgery, performed by the guy that invented that particular surgery, down at UT.
He told me I had less than a week left if the surgery had not been expedited as it was....
That one was rough. Due to the accelerated, aggressive nature of the tumor, the surgery was well over 8 hours and quite invasive. Bled to death in the OR, the whole shebang.
Took a long time to recover....hence the beginnings of the work on the GTX.
Followed that up with three more cancers in years since, including the thyroid one just a couple years ago.
Lost that chunk, too.
I'm missing some parts and got some cool gnarly scars, but **** still works, sort of.
So will you, Roger. Praying hard for you, man.
If my sorry arse can survive it, anyone can.![]()
It was for me for sure, but like I said, mine was pretty darn invasive (and death-defying, turns out).I'm not to worried about the surgery, it's the recovery. I'm used to doing what I want when I want. Doctor is telling me 4-6 weeks of light duty and no work. Like I need more time off this year. So far I've only worked a grand total of 8 weeks since January 1st.
I feel the same way, I can't stand anything stronger than prescription tylenol. The Doctor is telling me my tumor is 11cm and pretty aggressive. And the wife has already made arrangements to have me on lockdown.Oh, and PS:
Don't be an idiot and refuse all painkillers like I did. That's just a "me" thing.
Skeered of taking a liking to them. Seen too many good people ruined by addiction to opioids.
I was gutted pretty bad, even with the robotics doing the work.
I screwed up more than once, not listening to the surgeon and others in aftercare, too - I kept pushing things to get back to normal, sometimes causing more damage in the process.
Mule-headed, I reckon...
Threats of putting me back in the hospital finally cooled my jets for a few weeks.
I'd wait until my wife left for work, then sloooowly force myself out to the garage to work on something on the GTX every day without anyone knowing. That took literally minutes at first, me hunched over like the hunchback of Notre Dame, slowly shuffling as quickly as I could stand it.
That worked for a couple weeks, but she came home early one day and caught me under the car.
I heard the other garage door opener engaging and knew the jig was up.
Much fussing and such commenced, followed by a lot of "yes, dears" - but I had established a pattern that would both get me back in the swing of things, SLOWLY, as well as advance the revival of the GTX from death as well.
We both got better together, as it turned out.
As a result the GTX, as imperfectly flawed as she may be (ditto my own carcass), absolutely means the world to me.
Lookit, I pray and know your struggle to come won't be any worse than mine was but if I may, I can only offer a little advice from having gone through it:
Pre-surgery, exercise as much as you can stand. Build up stamina if possible, it shortens recovery time after.
Once the deed is done, when they're telling you to chill, DO IT. At least for a couple weeks....
After that, give 'em hell!!
You got this.![]()
